Results 1 to 8 of 8
Thread: ProSeries 20 x 48 Pro Series Frame Pool pump upgrade adapter
    Guest
    ProSeries 20 x 48 Pro Series Frame Pool with skimmer. I have this pool and a intex 2500 pump. has anyone found an adapter that i could use to remove the pump on skimmer so I can directly attatch the intex 2500 pump here link for pool http://www.meijer.com/s/proseries-20-x- ... _/R-216313
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: ProSeries 20 x 48 Pro Series Frame Pool pump upgrade ada
    Have a look in this thread. There are some pictures of an intex pump attached to a ProSeries filter.
    summer-escapes-pro-series-13-x22-rectangular-questions-t43440.html
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Guest
    That post was great. I thought of removing the impeller, but I wanted a cleaner installation. There was a link on that page for an adapter. That's exactly what I was looking for. I thought of using an intex wall strainer but then I would really have to modified the bottom hole on the strainer.
    Jul 2011
    844
    Hey billglass. I have 2 pumps on my ProSeries pool. The stock pump, and my Intex sand filter/pump. I cut the liner to do this. If you're interested I can send you the link to the thread.
    Bestway SWG
    Guest
    yeah, I would like to see it.
    Jul 2011
    844
    Bestway SWG
    Guest
    looks really good. what did you use to glue the reinforced material?
    Jul 2011
    844
    My neighbor had a contact cement for vinyl. Apparently you can buy this stuff at hardware stores.
    Bestway SWG
