Thread: Nitelighter
    Mar 2010
    Huntington, WV
    150
    Nitelighter
    I have the Nitelighter with the 35 watt bulb. What happens if I try to use a 50 watt bulb?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Nitelighter
    You will likely blow the 12v transformer, as it is rated for the 35 watt bulb.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
