Thread: Do I have a bad SWG cell or SWG?
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    All,
    I have been having problems over the last month keeping my fc at or around 5ppm.
    I shocked the pool last week in respose to my similar post to this as some suggested I may be fighting an alge bloom.
    I currently have my (oversized) SWG to 70% while running my pump ~8 hrs. a day and continue to lose FC.
    Overnight FC Loss Test resulted in an FC loss of .5
    Here is a set of numbers taken this morning:
    FC 2 (Down from 2.5 last night)
    CC 0
    pH 7.5
    TA 90
    CYA 75-78
    Curious if there is anything else I can check BEFORE I call the manufacturer and make myself soud stupid.
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Do I have a bad SWG cell or SWG?
    Your OCLT would tell me you are not fighting an organics problem in your water, and that sunlight is consuming your chlorine. Is your CYA really as high as you think it is? The Pool Calculator would put your target at 4 ppm. I would bump up the % and watch it for a few days. Is your water clear?
    I am running my IC40 at 60% on a 14K Gallon pool.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Water is clear.
    CYA test should be pretty close. (I was careful and thorough)
    I will bump up again and see.
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    After a simple test, manufacturer told me I had a bad LED controller. No matter how far I turned up the SWG it only got to 10%.
    By the way, the customer service at Circupool gets and A+.
    Part will be here Friday and I am told it is an easy install.
    100% covered by warranty.
