Results 1 to 8 of 8
Thread: Starting new pool with BBB method
    Jul 2012
    Toulon, Illinois
    43
    I want to use the BBB method. We are filling the pool on Wednesday and Thursday, what is the first things I should do chemical wise? I'm learning as I go and I guess this is the next step that I dont know much about. I have read pool school over and over and seem to be confusing myself more and more.
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Starting new pool with BBB method
    Purchase some bleach to get started! If you don't already have one, get a test kit from TFtestkits.net which will help you control your water by knowing the exact measurements of your water chemistry. As soon as you fill test it! The rest I can pretty much leave to pool school. Click the tab in the top right of the forum that says POOL SCHOOL and read it all twice! It will help you tons! If you have any other questions, we are here for you!
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    38,548
    much of the stuff you have read will start to make a little more sense when you get hands on.
    I agree you should order a kit sooner than later so you never have too fight with your pool.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    I was in the same boat as you just a couple weeks ago! I promise, it makes sense once you start doing it.
    1) Order either the TF100 or the K2006
    2) Buy some bleach to have on hand -- probably 4-5 of the big Walmart jugs is more than enough to start.
    Enjoy the new pool, we've had ours a little over 3 weeks -- LOVE it!
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
    May 2011
    Clearwater, FL.
    446
    See your other post... Don't get in a habit of too many topics in one forum!
    See here:
    installing-the-liner-t50222.html#p411111
    Try to keep on track in one posting, much easier for us to help you!
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    In addition to a test kit and bleach, buy some cyanuric acid (also called stabilizer or conditioner). Walmart often carries it under the label hth. That and bleach will likely be your fist two chemical additions.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jul 2012
    Toulon, Illinois
    43
    Do I want to use the 3 inch pucks in addition to the BBB method?
    38,548
    Quote Originally Posted by SadieBailey
    Ideally not. For one they continually add CYA, so eventually if you are not careful, the CYA will get to be too high requiring at least a partial drain of the pool. They are also very acidic, so they could result in your pH getting too low.
    Read pool-school/types_chlorine_pool and the rest of Pool School to get a better feel for the chemicals used.
    EDIT: OK, given your location are you going to be draining the pool every year anyway? If so, you may be able to get away with using the pucks, but you have to keep a close eye on things as they affect 3 variable at the same time. That is why it is generally "safer" to use chemicals that only have the desire impact to your pool ... and also usually be cheaper.
