Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Krystal Clear pump help with easy set pool
    We bought a used Intex easy set pool 18 x 42 with the Krystal Clear Wet Set pump. I think the model said it was model 50 or 53. It's raining now or I'd go out and get the exact model. Sorry! Anyway, we hooked the hoses to the skimmer basket and port which is the lower port and the other hose to the upper port. We hooked the upper hose from the pool to the side of the pump that holds the filter and the hose from the lower port on the pool to the side of the pump that holds the motor. There's water in the pump and it sounds like it's running but nothing is happening. It sounds like it runs for a few seconds and then shuts off. My husband tried to reverse the hoses thinking he had it backwards and the motor side of the port was flowing perfectly but backwards, thus pushing water back through the skimmer basket. We can't figure out what is wrong. It appears that there is an air bubble in the bottom hose underneath the pump and we've done everything to bleed the air out, but still nothing. Any ideas? it's like the motor is running backwards. We did happen to notice when hooked up correctly that the pump would work when we tipped it up on it's side to look for air in the bottom hose under the pump. Strange.
    Re: Krystal Clear pump help with easy set pool
    Since you purchased this as a used pool, you may not have the instructional manual that came with it. It tells you that when you first start up the pump, you must open the valve (the one that is hooked up to the skimmer) first. Then open up the one that is the output line. Then bleed any air out of the filter until you see water coming out. This is because if you open up the output line first, you will get an air bubble back into the pump. The lines are set up on a kind of gravity principle. If you opened up the latter first, it will push air into the lines. If you can't get the air out, try closing the valves to the pool...take the hoses off and unhook from the filter..... drain the pump. Reassemble and start over again.
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Coastal has some good ideas.
    When I have used that style pump, I just make sure both valves have the plungers up so that they are open, then before starting the pump, open the air bleed on the top of the filter part of the body, bleed the air out until water comes out, shut the air bleed vavle, and turn on the pump.
    I went online and found a video for a similar style pump and saw the thing about the order of which valves to open first. However, he had already tried to start it without doing that, so that's probably why we have the air bubble. I'll have him unhook the hoses from the pump (with the valves shut of course) and see if we can start over on it. I'll keep you posted!
    so on an Intex easy set pool, is the lower hole on the pool considered the intake to the pump or is it supposed to be the lower one?
    I believe that the higher on I suppose to be the intake on the pump, so the higher one is removing water from the pool and lower one is putting it back into the pool.
    Intex Ultra Frame 14 x 42 3500 gals
    Intex SWG combo unit (2000 gph), screen door screening around cartridge:-).
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Trying to remember. . . But don't the easy set pools and pumps have "+" and "-" signs on them to aid in hooking them up? "+" to "+" and "-" to "-"?
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    That must be the case. I did see a plus sign on the side. We didn't get a manual with it. I think we finally got it figured out. The problem is that the skimmer basket keeps floating up sideways and then gets air in it. Any ideas on how to get it to stay put, up and down? We're afraid to tight the clamp down too much for fear of rupturing the ring.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I thought the lower hole was the intake to the pump and the higher hole was the return to the pool??
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    The lower one is the intake, the higher the output. The thing with the easy set and the ring is tricky. I have heard from others that if you don't keep the ring inflated just right..the skimmer can tip over and you start sucking in air. You need to get it as tight as possible. I for one would only want to run the pump when I could be around to kind of watch and make sure everything is ok with it.
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    Thanks so much! I think we got it!
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    A side note. The ring pressure also fluctuates with the air temp. If you inflate the ring in the heat of the day , it will soften in the cool of the night. This can also make the skimmer bracket slip. Some on the forum have made PVC brackets that sit on the ground outside the pool and reach over the ring and hold the skimmer in the water. This would bypass the ring altogether.
    Angie M.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Here's a link to the thread with the PVC bracket holder/frame thing
    intex-easy-set-skimmer-bracket-t36157.html?hilit=easy%20set%20skimmer
    Angie M.
    Quote Originally Posted by dacer123
    Jul 2012
    NW FL
    91
    Before leaving this topic, can I ask if it matters much, or why it would matter if the water leaving the pool through the skimmer basket at the highest opening and the return water is going through the lower opening. We hooked up the hoses this way so the skimmer basket is easier to reach. We have limited space and it is tight quarters by the pump/filter where the lower opening is located. Thanks, have been wondering this....
    Thanks
    ~6500 gal 18' x 52" easy set agp, 7th year
    Intex 2650 sand filter, chlorine
    TF100 Test Kit
    Becoming a TFP lifetime supporter and purchasing the TF100 is absolutely the best money I have ever spent! :-D
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    It does not matter one bit, if you know what you are doing.
    Intex prefers to extract water through the lower opening to lessen the probability that someone's (long) hair might be sucked in through the strainer.
    Jul 2012
    NW FL
    91
    Yikes! That's a freaky picture! Don't remember seeing THAT in my manuals, but it makes sense. We never have the pump on while we are in it anyway? Thanks... I was just wondering if it helped / hurt w circulation.
    TF100 Test Kit
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    For whatever its worth, when the pump gets air in it, tip the sucker so the outlet is higher. Air purges. these pumps get a lot of yrapped air inside, multiple times a day. Especially if the filter needs a cleaning.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
  20. Back To Top    #20
    I'm not sure what you mean by tipping the sucker. Do you mean the pump or one of the hoses. Our skimmer basket has a hose on the bottom of it that goes down to the inlet hole that then goes to the pump.
