Thread: pavers vs. wood under legs
    Jul 2012
    San Jose, CA
    13
    I'm getting ready to set up a 16' x 48" Intex UltraSet.
    I'm going to get some building rigid foam to put under the liner (as padding from possible rocks plus insulation). The question is whether to use pavers of about the same thickness as the foam or pieces of redwood or pressure-treated wood.
    I have to check what thicknesses of foam I can get at the local Home Depot (we're in Northern California, so they often don't have the thick stuff used in more northern climates).
    Any pros or cons of about 1" thick pavers verus two redwood fence boards (assuming the same surface area)?
    5000 gal, Intex 16'x48" above ground, Intex 2000gph cartridge filter w/SWG, TF100 Test Kit
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: pavers vs. wood under legs
    Wood has worked well for us, going on 3 seasons now. A few have split, they need to be replaced.
    Oh, I've never taken this pool down either. Thus, a few split. For seasonal use, they'll work just fine.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I used concrete under mine. Be sure to get the hard concrete ones and not the concrete like in cinder blocks. The cinder concrete ones break... I know from experience. See if you can find them on craigslist for a "haul them away" free price. You really don't care what they look like... they are going to be covered in grass/mud/dirt and pool.
    Wood rots and splits.
    -- Guy --
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Wood for a seasonal pool should be fine. Pressure treated wood even better than cedar fence boards, but the fence boards can also work. I'm just saying, wood is a viable option, especially for pools only up for few months a year.
    To replace them, we can lift on the pole just a bit, and another is slid into place (thin works for us in this situation). Only two have split. This is an intex metal frame pool on year three, where it rains 10 months out of the year. It's seriously moist here.
    I think the kids would have stubbed some toes if we'd used concrete pavers. I have very little space for a pool, it takes up nearly the whole yard (a garden is 1 foot away as well). Pavers would stick out a lot in this case.
    Jun 2012
    MA
    347
    If your ground is packed down enough you don't need anything under the poles for a round Intex pool. I went two years with an Intex 12'-3' pool with nothing under the poles. The poles on the pool do not have that much force on them. It is best to put something under the poles. I have a 15'-4' Intex metal fram pool this year with 7"-7"-1/4" plywood under the poles. You could use thin books under the poles.
    The rectangular pools need more support. The round pools are almost free standing.
