Results 1 to 15 of 15
Thread: yet another conversion
    after reading up on this awesome thread for several months, I started the switch yesterday at 4pm
    some info: pool is 15000 above ground sand filter
    first color after nine 182oz 6% bleach, was a nice dark brown, went to second job and at 11pm added another 5 bottles of bleach, color was brown/green
    at 7am it was dark pea soup, added another 9 bottles
    checked numbers, added another 3 bottles, and currently the color is light pea soup.
    once the conversion is complete I will be using BBB.
    one question, it was supposed to be sunny all day, it is overcast with lite drizzle, will this be negative to the conversion? I figure that less sun is good and will make it quicker.
    Zuk
    18x33, 16k, AGP, vinyl, 3/4 HP Pump, Sand Filter, TF-100 test kit.
    30,403
    Yeah, your chlorine loss to the sun will be less. Most of the UV still pnetrates clouds but there is some reduction (that's based on observation....it may not hold up scientifically)
    Nice work on your conversion. Light pea green will most likely go to cloudy grey-blue and then sparklling clear. The last little bit may be tough but keep the chlorine in there and keep that pump running....you're not far from completion.
    BTW, welcome to the forum
    Butterfly's Avatar
    South Carolina
    10,045
    Hi zukker23 and Welcome to TFP!
    Another conversion! From Baqua to Beautiful.....soon!
    Post some pix when you get some time.
    You're done SLAMing when:
    sand question
    Thank you for the welcome....it really was way to easy of a conversion.
    Here is the history, last year in July, I decided I was switching. I was tired of the cost and crapy looking pool no to mention the number of hours spent. So I stopped adding anything baquacil. I had no problems(surprise) with the pool and closed it at the end of september(early for me). When I opened in the beginning of April, no problems. Let me add that I emptied the sand at the end of last year, it was due. So I added sand when I opened this year. I began running the pump for 4 hours a day up til the switch this weekend, it has been running 24 since.
    I am now complete, the pool looks incredible, I will add pictures soon. I took pictures everytime I added bleach.
    I had no orange goo, nothing floatign on top, nothing in the skimmer, and during backwash, nothing but water...my question is should I still change the sand? My gut says I will be fine but my head is saying change it to be safe? Give me some feedback.
    Thanks again for all the posts about the change, it made it really easy and I felt confident it doing it.
    Zuk
    latest test: 7.5 ppm FC, 7.2 PH water temp 68, just put heater on, it will be 73 in 30 mins.
    my girls, ages 3.5 and 4.5 are going in, so that means me too.
    Zuk
    30,403
    Each pool is a little different and your conversion seemed so painless, I question whether you could get away with not changing out sand.
    My thinking is to get your pool nice and stable and see how much your daily consumption of Chlorine is. If it's greater than around 2ppm, you could probably blame residual bacuagoo in your sand and change it then.
    If you use 2ppm daily or less, I am not aware of any other long term effect.
    That is pretty much my thinking on it as well.
    Just got out of pool, feels great and it is soooooooo clear.
    A bit cool for staying in long but when the girls ask you gotta respond
    Zuk
    Re: yet another conversion
    day 1 photo
    Zuk
    day 2 photo
    Zuk
    day 4 photo
    Zuk
    bleach used
    Zuk
    Wonderful pictures! Congratulations!
    Butterfly's Avatar
    South Carolina
    10,045
    Great job!
    Also, nice deck and grass!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Great JOB! Thanks for posting the pics, more evidence for the masses!
    Thank you for the comments and help, the test kit is so easy to use.
    About the deck, I am all about low maintenance so we went with treks and a white plastic rail.
    Low maintenance is also the reason I have made the switch, everyone who has been over has commented on how nice the pool looks
    Zuk
