Results 1 to 17 of 17
Thread: Dead bird in the skimmer - time to superchlorinate?
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    So I found a dead bird in the skimmer, so I think I need to superchlorinate my pool to be safe. Since my FC and CC levels are currently fine and the water is clear, I assume I add enough bleach just once to bring the FC up to the specified shock level? Based on a CYA level of ~40, I'd need to add enough bleach to bring the FC from 6 to 16, or 373 oz (based on the Pool Calculator).
    How long should the pump be running BEFORE and AFTER I superchlorinate the pool?
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    Mar 2011
    Sunny Central Florida
    91
    Re: Dead bird in the skimmer - time to shock
    I'd bring it up to shock level at night and do the OCLT. If you don't lose any CL overnight, you don't have any nasties in your pool that need killing
    I run it 10 or 15 min before bleach, and the recommendation is to run the pump at least an hour after you add any chemicals.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Thanks. So I could start the pump back up tonight and add the necessary bleach and let the pump continue to run overnight and into its next normal cycle?
    Just a side note....If I shocked every time I had a dead critter in my pool, I would be shocking daily. Had birds, bats, voles, snakes, frogs, chipmunks....just sayin............. Maybe the pros will chime in.
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    True, I am assuming I need to shock. The little guy (baby mockingbird) was not in there for very long, but I read some other threads that mention shocking when there are dead animals in the pool. I am a total noobie, so I will also wait for the pros
    Jul 2012
    Newton NC
    31
    I'm with samiguy, if shocked every time I had dead critters, I would shock everyday. If you are having company soon, empty the smelly skimmer on the other side of your property.
    16k 17X33 IG Vinyl(2000), Pentair Intellifo Variable Speed Pump(2006), Hayward Sand Filter, Aqua Rite SWG w/T9 cell(repl 7/2011), Hayward Natl Gas Heater, TF100 w/magnetic stirrer
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    A new house is being built on the lot next door and that dead bird may/may not have ended up over there
    May 2011
    Ft. Lauderdale, Fl
    39
    LOL AaronGo! same here...my neighbors behind me are snowbirds...so snakes, birds, mice, etc may or may not end up under their bushes when they are not here for the season! I also agree that as long as you maintain normal chlorine levels you shouldn't HAVE to shock every time a nasty something or other dead ends up in your skimmer....HOWEVER, when my dog decides to use the pool as her own toilet bowl on rare occasion (i'm not quite sure how she maintains her balance, teetering on the edge like that)...I DO an overnight shock...after scooping of course...bleck!
    32x16 -16,500 gallon plaster pool with connected spa and spillover, Hayward RS 1 HP pump, 2 Hayward Cartridge filters. 10 hours of direct sun a day and a first time pool owner!!
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Re: Dead bird in the skimmer - time to shock?
    So any other thoughts on this? My gut says if the FC levels are within range, then this one instance does NOT require me to shock the pool, but not 100% sure.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Use your cc reading as your guide. If it's more than .5 cc, shock. If not -- you're good to go IMHO. I regularly get various dead woodland animals in the pool.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Good call, I will perform that test this evening and do what is necessary.
    jule's Avatar
    New London, Wisconsin
    139
    Ha ~ Same here. Just this morning a mouse. Along with a couple frogs. Apparently frogs don't communicate the way ants and wasps do, or they'd put out an alert to stay away from my pool. lol!
    22 ft octagon, inground, 4 ft ave depth - figured @ 11,400 gallons, well water
    Steel walls with sand bottom and vinyl liner : under full sun
    Harmsco Betterfilter w/14 paper cartridges
    1 hp Hayward motor
    Baqua to Chlorine in 2010.
    ~Wisconsin~
    OK...add lizards to the list..think I found the Geico creature in the skimmer today....called him "Cleatus" when he was walking around the pool......dang..........my new friend is dead...........
    38,457
    Can we stop calling what you are talking about "shocking the pool"? You are talking about a single boost of FC which is NOT what we typically call the shock process.
    We struggle to make everyone understand that "shocking" is not a 1 time thing or a product, but a process that must be followed.
    Just trying to be clear for any new people that may be reading this ... I will now return to my hole
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    fair enough, I edited the title and my first post to be more accurate. I even mentioned doing a one time chlorination to shock level the first time around, so should have been consistent.
    Re: Dead bird in the skimmer - time to superchlorinate?
    Sorry if I confused anyone with my comments. Yes, shocking is a process, not an event. Maybe we can introduce another word like "pulse".... Nah, just more confusing. I just think of it as I saw somewhere here at TFP...shock is a verb, not a noun. Thanks!!!
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    FYI, my thread was inspired by another thread in the Chem 201 section about a dead animal in the pool in which the term "shock" was referenced several times, but as "increasing FC to shock level".
    I think "super-chlorinating" is more accurate since what I was asking about is a one-time event to raise FC to shock level, which is far different than the actual shock process to address algae, etc.
