Thread: need automatic pool cover pump...any suggestions?
    newbie here to the forum.
    i need an automatic pool cover pump for my coverstar pool cover so i can close it when it rains.
    any suggestion as to the best one to get? where also is the best place to buy it/
    thanks in advance.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: need automatic pool cover pump...any suggestions?
    I have a Rule 1800 gallon-per-hour pool cover pump that works quite well. You can get one on Amazon for around $110. This is for my electric safety cover over a 16'x32' pool. It automatically comes on for a few seconds every few minutes to see if there is any water (it can tell by feeling resistance) and if there is then it stays on until the level drops. You just need to attach a hose to it. I pipe my water back into the pool to overflow it during the winter since that's how I dilute the water each season, but you can of course pipe it to a storm drain instead.
    thanks so much.
    Mar 2007
    San Rafael, CA USA
    12,082
    And welcome to TFP!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, earlybirdnj
