Thread: Pool help
    Pool help
    Hi there. My pool is cloudy and we have different opinions if it is slightly green or not. I'm not reading any CC's, so I don't know what to make of it. I'm trying to decide if I should shock and hold for a day or 2, or just try adding clarifier. Here's my numbers:
    FC 4.5
    CC 0
    pH 7.7
    Alk 110
    CH 140
    Cya 40
    My chlorine is typically around 5, but there was one day (right about the time it started getting cloudy) that it dropped down to 1.5.
    Any advice?
    Thanks!
    Mike
    30 foot round AGP (25k gal), 2.5 hp pump, Hayward cartridge filter, Diver Dan pool vac, TF-100 Test kit
    -It takes less time to do things right then it does to do it again.
    38,290
    Re: Pool help
    Bump the FC up a bit (say 10ppm-ish) and do an OCLT. That will tell you if you should go through the full shock process.
    Clarifier should not be needed with a cartridge filter I don't think.
