Results 1 to 17 of 17
Thread: Converted in Seattle
    May 2008
    Seattle, WA
    12
    New to forum. Posted my intro already
    Just finished conversion to Chlorine. Yea! Here are the stats: AG, 18x38x4 (16000 gals)
    numbers this morning:
    55 degrees water temp
    175 TA
    7.4 pH
    30 FC
    2 CC
    CH 100 (vinyl liner)
    CYA 30
    water slightly cloudy, about to change sand filter today
    What do you think? Doing Ok?
    AG 18x38x4 (16,000gals), sand filter
    Mar 2007
    Texas
    444
    Looking pretty good, you still have a little bit of the pesk still in there so keep the CL up, got any pics of conversion?
    27' Round AG, 17,200 gallons, sand filter
    Feb 2008
    Charlotte NC
    44
    Re: Converted in Seattle
    Quote Originally Posted by Seattlevue444
    175 TA
    7.4 pH
    30 FC
    2 CC
    CYA 30
    A couple of questions:
    First: If you just converted, how did you get so much CYA in your water? Usually it takes a while to dissolve. Could it be that the cloudiness of your water is affecting your CYA test?
    Second: With a vinyl liner, your FC seems high. When I did my conversion, I shocked to 20 and kept adding bleach to keep the level that high. Was it your intention to go that high? Or is there a typo?
    22,000 gal, IG vinyl, 3/4 hp pump, 300lb sand filter (switched from DE), converted from baquacil (thanks to Ben), BBB since 2004
    May 2008
    Seattle, WA
    12
    new numbers in Seattle
    Well, after 2 days-in a row- of dry weather here are the numbers 2 weeks after start of conversion:
    60 degree water temp
    12 FC
    1 CC
    7.3 pH
    130 TA
    210 CH (?) went up
    CYA not sure, got a reading of 30 (dichlor had been added during conversion-not my idea) Pool place read 0 last week
    Water clear, still some fine dirt at bottom, will be vacuuming again
    We are expecting rain(surprise!) so all may change by tomorrow eve. So, what now? Continue to get FC down? All of this is very new, I am so use to Softswim... All help very welcome
    AG 18x38x4, vinyl liner, sand filter
    Keep FC up around 15 until CC reads zero and the water is clear.
    May 2008
    Seattle, WA
    12
    Thanks for the advice! Been awhile since a post. All week the pool has been FC 16 at night, 13.5-14 in the morning with 1 CC. Looks clear during the day, but turn lights on at night and it is slightly cloudy. Just vacuumed again and checked numbers:
    58 degree water temp (we will not be swimming here in Seattle for awhile it looks like )
    9 FC
    1 CC
    7.6 pH
    140 TA
    I am considering another 1 gal tonight-what ya think?
    30,421
    Seattle,
    Keep your FC up around 15.
    Are you brushing the pool and running the pump 24/7? It sounds like you may have a few organics floating/settling on the bottom and they neede to be vacuumed all the way out or stirred up so the filter will get them out.
    If you'll get those out, I think that 1cc test result will go to .5 or less and I think your FC will hold steady (almost) overnight.
    You need to keep at it. The CYA is slowing everything down, normally it goes a little faster.
    If CYA is at 30 you can bring FC up to at least 20, which will help a little.
    May 2008
    Seattle, WA
    12
    Oh Mighty Gurus, your advice will be followed
    Will post in the morning, have a good evening!
    May 2008
    Seattle, WA
    12
    Finally warm!
    So, it has been awhile but thought I would post some numbers and get thoughts:
    water temp 72 and climbing
    5 FC
    .5 CC
    7.8 pH (just added a pint of mur acid to tweak down)
    TA 125
    CYA <20
    The pool looks clear during the day, but when i turn lights on at night I still see a white haze/particles? Not really sure what it is...
    how am I doing?
    Warm in Seattle
    How is your overnight FC loss doing? Have you held the same level overnight yet?
    CC is very low, which is a good sign.
    Particles seen at night are fairly common and difficult to get rid of, nothing to do with a baquacil conversion.
    May 2008
    Seattle, WA
    12
    While maintaining 15 FCC it would drop between 1 to 1.5 overnight. It was very warm Friday (90-that's warm for here ) and I noticed it had dropped 10 from friday morning test to Saturday morn test (did not test friday night). We had been backwashing/vacuuming, so needed to add water which I think helped to bring down the CYA level. I was checking the CYA/chlorine calc and if reading right, I need to maintain a min of 2.4 chlorine to the 20 CYA. Still not sure I am calculating chlorine right for 16,000 gal--1 gallon chlorine raises 10,000/5.25--what is that for 16000? Why is this so hard? I think by head is still full of Softswim goo. And why shouldn' the water be clear even at night?
    You might want to try out my Pool Calculator, see the link in my signature, for figuring out things like how much bleach to use. For a baquacil conversion you can raise FC up to high shock level, which is labeled "Mustard Algae Shock" in the Pool Calculator.
    1 gallon of 5 1/4% chlorine added to 16,000 gallons of water raises FC by 5.25*10,000/16,000 which comes out to about 3.3 ppm.
    The water should be clear and quite transparent. None the less, at night with a pool light or flashlight you can still see particles in the water that the filter can't take out. That is normal. I am assuming that is what you were describing.
    Butterfly's Avatar
    South Carolina
    10,045
    Do you use skimmer socks? If you don't use them, then you should get some!
    We always use them and they are a big help in keeping our water sparkling clean
    You're done SLAMing when:
    May 2008
    Seattle, WA
    12
    Skimmer socks? No, I have not heard that...
    Butterfly's Avatar
    South Carolina
    10,045
    Well, I really like the "Aqua Chem" Skimmer Screen that I find in WalMart.
    We use the socks (screens) year around. When I pull one out I immediately replace it with a clean one. Then I clean the used one and it is ready for the next tour of duty! Time between cleaning/replacing depends on what is happening in the pool! Leaves, pollen, etc.
    Brushing often will also help the fine stuff get to the skimmer and out of your pool!
    You will love your cleaner water. 8)
    May 2008
    Seattle, WA
    12
    Thanks for the tip!
