Results 1 to 12 of 12
Thread: New AGP pool. Need advice
    Jul 2012
    Freedom, WI
    14
    We are currently getting an AGP installed inground and the liner and water is in the pool but the filter and pump will not be hooked up until the concrete work gets done. What type of chemical treatment should I do in the meantime in case it takes 3 or 4 days for this to happen?
    Thank you.
    I ordered a TF-100 kit today and plan on doing BBB when I get the kit.
    Should I just add some for now and stir it up?
    22,548
    Re: New AGP pool. Need advice
    Add about 3 ppm FC each evening using bleach and stir it well with a brush. The pool calc will help you figure out how much that is.
    Once you get your test kit you can post a set of numbers.
    Jul 2012
    Freedom, WI
    14
    Ok. Since I don't have the test kit yet. Is that a cup, 2 cups, 1/2 gallon of bleach?
    Is it safe for kids to swim in it?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    It depends on the pool size. If you don't know who many gallons you can go to PoolCalculator.com and enter the dimensions into the boxes near the bottom of the page. Take the number of gallons from that calculation and place that number into the "size" box at the top of the page. In the next row FC, enter 0 in the first box and 3 in the second box
    Here a screen grab
    -- Guy --
    Jul 2012
    Freedom, WI
    14
    Thank you.
    I think I did it right. 16' x 28' oval x 5.9 (6' deep end 4' shallow end). I got 13,216 gallons - 82 oz of bleach or 5.8 oz of trichlor.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I would highly suggest the 82 oz of bleach...
    -- Guy --
    Jul 2012
    Freedom, WI
    14
    So three weeks with no pump yet and I have been dumping bleach in and keeping it clean.
    I did put some stabalizer in the other day and now the pool seems to be getting cloudy.
    Here were my measurements. Hopefully the pump and filter are getting started today. I think the cloudiness is due to concrete dust and dirt that has gotten in the pool over the last 3 weeks.
    FC - 12
    CC - 0
    CYA - 25
    PH - 7.5
    If it is cloudy should I raise the FC or do you think it just needs to be filtered and cleaned?
    May 2011
    Clearwater, FL.
    446
    Just keep your FC 12-15 and you'll be fine.
    Brushing to keep it mixed.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Apr 2012
    SW Ohio
    456
    Agree with supertune and brush,brush,brush that creates turbulence in the water to help in mix
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    22,548
    It getting cloudy doesn't surprise me with no pump filtering for that long. Once you get it going you'll see a big difference.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Without a pump one has to believe your fighting an uphill battle, I can't see maintaining it adequately with stirring. This technique was only going to buy you a few days - not weeks.
    You need pump/filter asap and then probably have to shock it.
    Jul 2012
    Freedom, WI
    14
    Pump is going and the pool is crystal clear. The stirring method worked pretty good for 3 weeks without a pump. The last straw was the concrete dust I think. Now just the fence and landscaping and hopefully a warm August and September in WI.
