Thread: big rain and cya is almost gone ? ?
    hey guys, my cya has been running 35-40, we got 5 inches of rain in about 2 hrs a week ago, i go and check my cya today and it said 15-20, checked it twice, i do have an overflow drain, so the rain brought the pool up about 1 1/2 inches before it started going in the overflow that day, does this much rain usually make the cya fall that much ? ( testing done with the tf-100)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: big rain and cya is almost gone ? ?
    With an accuracy of +/-10ppm on the test, you could easily see that kind of change.
    ok, guess its time to add some pucks to bring it back up to the 35-40 range
