Results 1 to 7 of 7
Thread: What to do pool is filled
    Jun 2012
    central coast CA
    7
    New to TFP Waiting for my test kit, should I add bleach now? 15,000 gallon AG sand filter excited about the bbb method and don't want to get behind. My teenage son will be helping me with the testing, he is taking chemistry on the fall so it will be perfect
    Thank you
    15,000 gallon kd 16x33x42 AG. Sand filter TF 100 test kit
    BBB method
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: What to do pool is filled
    I would. I'd also start adding CYA, since you can be sure it is zero right now.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If the pump is running, yes. You'll go through it quickly in the sun, so you need some source of CYA. Either add the CYA through the skimmer, in a sock, or by using trichlor or dichlor to chlorinate. I'd add enough chlorine to get to 10ppm, then let it fall until it gets down around 3ppm. Use poolcalculator.com to figure out what you need, but for 15,000 gallons, each gallon of 6% bleach will add 4ppm to your chlorine level.
    Jun 2012
    central coast CA
    7
    I know this is such a newbie ? Where do I purchase cya? What should it say exactly on the bottle?
    Home depot. Or pool store?
    Thanks again
    BBB method
    38,475
    CYA = cyanuric acid
    pool-school/recommended_pool_chemicals
    Can be found at Walmart or pool stores ... not sure about the hardware stores.
    Apr 2011
    Lynchburg VA
    393
    I know Lowe's carries CYA....labeled as stabilizer.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    It may also be labeled as conditioner. The label will have a chemical breakdown, look to see that it is near 95% CYA
    -- Guy --
