Thread: IntelliBrite Lights only in Red
    Durham, CT
    34
    I have two IntelliBrite Lights in my pool; not sure exactly what model they are. The were installed 3 years ago when the pool was build. One of the lights now only lights up red. For example, when I turn on the "Caribbean Mode" I see the light switch to blue for about half a second but then go back to red and stay red.
    Is this light bad? Is it a strange way for the light to fail? Anyone else seen this?
    Thanks!!!
    24000 gallon Gunnite Pool
    WhisperFlo 1.5 hp Pump
    AquaConfort SWG System
    Solar Heating System
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    416
    Re: IntelliBrite Lights only in Red
    How are you controlling them.. via an Easytouch
    LED's work off Hertz or frequency. If they are getting one color they should work on others. I would suspect the programmer over the light
    Have you called Pentair. They are sometimes good. Depending on tech you get.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Durham, CT
    34
    Thanks for the reply. I control them via a simple switch. Basically flip the switch 8 times to get the Caribbean mode. I figured it must be the switch since the other light connected to the same switch works fine. I have contacted Pentair via e-mail but all I got was "You can confirm that the light is getting the multiple signals from the switch or relay if it is in fact clicking multiple times and that light is not cycling the color properly it would need to be replace". Not really sure what that means??
