Thread: Am I running my pump enough?
    jtb33's Avatar
    Jul 2012
    Phoenix, AZ
    27
    Spec's:
    15,150 gallon in-ground pool
    2" PVC piping
    2HP Tri-star pump
    Salt system (if it matters)
    I live in Phoenix, AZ.
    I was running my pump for about 10 hours a day to clean things up. Right now, the water is *perfect*. Pool is absolutely clean, chemical balance is great and water is sparkling. I recently bought four new cartridge filters, and cleaned the salt cell, etc. We're good.
    So, now, I'm thinking that if I don't need to run it that much, I can save on some electricity costs. I don't know the GPM my system pushes. I do realize that if I lower the run time, I will need to increase the % for my salt system.
    Anyway, I was thinking of dropping it to six hours per day and see if the water remains sparkling after a week. Think that's OK?
    Also, trying to decide to run the pump for 6 hours straight, or for 3 hours on (say, 6AM-9AM), then again that day from 4PM-7PM.
    My pool:
    89' perimeter, 15,150 gallons, depth: 3x5x4
    Hayward C5025 w/Hayward 2HP tri-star pump, 2" PVC piping
    Goldline Pro Logic P4 w/salt system and Aqua Pod wireless remote
    Magnasweep in-floor cleaning system
    Pebbletec Caribbean blue
    Grotto w/waterfall and rock slide
    Play-step w/water feature
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Am I running my pump enough?
    It's all trial-and-error. pool-school/pump_run_time
    I get by with 4 hours, plus some extra here and there when I'm vacuuming or adding chemicals outside the programmed run time. I have an hour around noon, just to keep things mixed, and the rest in the evening when we're most likely to be using the pool.
    Jul 2012
    Herndon, VA
    419
    Not to hijack the thread....
    new to pools here too. I've got a 12,000 gallon fiberglass pool, with a 1 hp whisperflo pump.
    Previous owner told me he ran the pump 24/7.
    I've got a handle on the testing using the tf-100, so I don't think I'll need to run the pump 24/7. Should I start off running it about 12 hours a day? I plan on turning the pump on right before I add the daily dose of 6% bleach, and leaving it on all night until I wake up in the morning to turn it off.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Jul 2012
    Herndon, VA
    419
    to be clear...I plan on adding the dose of bleach at night, around 11 pm or midnight...
    38,245
    12 hours is a good start ... that is likely more than you need as well. Just keep shortening run time until the pool is not as clean as you like.
    See the link that Richard posted.
