Results 1 to 7 of 7
Thread: Pump rebuild- Hayward Super Pump & Max Flo
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    I have two pumps that run, (were given to me) but don't seem to suck or pull water through. There is no suction side leak because I had tested them with a direct line running into my pool. Both motors run fine, but again just no suction. They have new lids and orings on the strainer baskets.
    Both are Hayward pumps.
    One is a Super Pump 1 HP and the other is a Max Flow 3/4 HP.
    Q- what seal or seals would make these not work.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    38,301
    Re: Pump rebuild- Hayward Super Pump & Max Flo
    So you just put a short pipe from the pool to the pump and then back again?
    I am wondering if you actually have too little head loss and that is causing the problem.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    The suction line is about 12 feet... 6 feet to the pool then down about 6 feet into the water.
    But getting suction leak and its not the lid and I believe the impeller is free.
    ColorQ Pro
    TF-100
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    Also the plug is good and sealed.
    LAST both pumps were left outside for two years in New England- not connected to anything.
    ColorQ Pro
    TF-100
    38,301
    what plumbing is on the return side?
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    Just a short maybe 3 ft line on the return side.
    I guess what would be the best way to test a pump for suction if it is disconnected from the pool. ??
    ColorQ Pro
    TF-100
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Is the impeller intact and turning?
    Keep the return line vertical, fill it with water (from a garden hose) and see if the pump can push it out.
    Donīt be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
