Thread: VALVE & SKIMMER QUESTIONS
    We are in our 50's and the proud owners of our first home with a gorgeous pebble tec DE filter pool with waterfall and rock walls....extremely nice...but being new to all this we hired the local Leslie's franchise to come and do a pool school for us which helped us tremendously but there are still lots of questions and so hopefully...with pictures to help identify things we just need to know what a couple of things are for..first of all in the first picture is the skimmer bottom where it shows two drain holes...one of them has a strong suction and is where we hook the vacuum up...what does the other hole do? We have an unidentified pvc pipe that goes the entire length of our house about 10" down but we haven't dug it all the way up nor found the end of it yet...does the pipe have something to do with this second hole? In the second picture from poolside...I believe from research that I have done that this is a water leveler...somehow you adjust the valve to a certain heighth and then the water level never goes below that. If that is the case then what exactly is the function if the pool has just endured 4" of rain and has gone above the skimmer...does the leveler drain it down to the original level? Finally in the third picture from poolside is another lid over a hole and we don't have a clue what it's function is. It is about 3 feet from the leveler...in the pool directly aside of it is a drain hole of some sort but there is no pressure water going in or coming out. If not anything else we would like to know what it's function is so that we can use it if it is for something we really need it for...especially after enduring these desert storms that dump a quarter inch of dirt into the pool with a good storm and just about overflow the pool every time! Thanks for you help![attachment=2:2jejskrr]pool071612faqforpoolschool 003.jpg[/attachment:2jejskrr] [attachment=1:2jejskrr]pool071612faqforpoolschool 002.jpg[/attachment:2jejskrr] [attachment=0:2jejskrr]pool071612faqforpoolschool 001.jpg[/attachment:2jejskrr]
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: VALVE & SKIMMER QUESTIONS
    Hi, welcome to TFP! Sorry but I don't see any photos attached to your post. You can use a photo hosting site such as photobucket to host your pictures if you are having trouble posting them.
    Love TFP? Become a
    TFP Supporter!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, claymatey
    Looking forward to your pictures!
    Apr 2012
    Klein Tejas
    249
    I see the pictures
    The second hole in the bottom of the skimmer is intended to prevent air entering the skimmer line if the water level is too low.
    Many times this second connection is tied into the main drain suction line, rarely it might have it's own fitting in the wall of the pool or sometimes it's plugged entirely.
    Yes, the second picture is an automatic water filler. I don't believe it will lower the water level in the pool only add water that has evaporated.
    I'm a newbie so the third picture I can't identify. Maybe a vacuum release?
    Pool is DONE!
    Pentair Intelliflo VS3050
    Pentair Easy Touch 8 + actuators + swg
    Pentair IntelliPH
    Pentair 400btu HD heater
    3- Jandy WaterColor LED's
    Hayward C5030 525sqft cartridge filter
    Waterway spa blower
    Jul 2012
    CA
    240
    Could the 3rd pic be a valve for your floor cleaners??? Do you even have them? they are a bunch of little jets that pop up on floor to get dirt.
    25k I/G ecostar ccplus Polaris plaster
