Results 1 to 13 of 13
Thread: Installing the liner
    Jul 2012
    Toulon, Illinois
    43
    Tomorrow we will be installing the liner to our new pool. Its a used pool but brand new liner. My question is, do I need to open it up and let it sit in the sun tomorrow to warm up so that its easier to work with? My father in law advised me to do this but I'm wanting to make sure he is correct. Thanks for your help.
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Installing the liner
    yes, a warm liner is more pliable and easier to work with. The warmth will also help the liner to stretch properly as the pool is filled.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    Toulon, Illinois
    43
    Thanks zea3. I have been reading about it online...really nervous about cutting the liner for the skimmer and water return lol
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Yup for sun and yup for skimmer cutting stress, make sure the water is filled near the skimmer and then cut, I was stressed as well but it's not that bad.
    Good luck!
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Depends what you call warm. A liner that is really hot is almost too pliable to be easy to work with. At this time of year I would think it would be plenty stretchy with just a small amount of time in the sun. If the pool is in the sun while you are installing it you should be fine, it will warm while you are juggling it. The tips on waiting to cut are a must. What size and shape is the pool? What kind of liner? (beaded, overlap...etc)
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jul 2012
    Toulon, Illinois
    43
    21 foot round, 48 inches deep. overlap liner
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    As for cutting you skimmer hole. I installed skimmer completely before cutting the liner by following the edge of the inside of the faceplate.
    -- Guy --
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Pretty sure I did the same as techguy.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Round is easier than oval but that's pretty big. Keep us posted.
    Mike
    Jul 2012
    Toulon, Illinois
    43
    Liner is in with about 4 inches of water so far. Liner went a lot more smoothly then we expected![attachment=0:9ctaq7i0]071712172504 (480x640).jpg[/attachment:9ctaq7i0]
    Jul 2012
    Georgetown, KY
    31
    we also cut the skimmer and return holes after we had them installed. we let our liner sit out in the sun for a few minutes, but it had been sitting in our garage for a couple days and the temp was over a 100!
    Morada AGP 24 foot, 52 inch deep
    DE filter, 2hp pump, inline chlorinator
    Set up on July 1st, 2012
    Goal is to use the BBB method!
    VERY new to the pool scene!
    Love the Pool School, still learning so much!
    Thank you in advance for your advice and help!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Looking like you will be wet this weekend. You might add a cup of bleach or so if you have not finished installing the liner and installing the pump and filter.
    -- Guy --
    May 2011
    Clearwater, FL.
    446
    Hi SadieBailey,
    Don't forget the other most important Snap-On tool, your TF-100 test kit from here:
    http://tftestkits.net/splash-page.html
    Test you fill water first, then we can tell you what you need.
    For sure you need powered Stabilizer/Conditioner/CYA, (get from Walmart or Home Depot)
    Lots of bleach, buy 8 gals to start, (I got some liquid chlorine locally in 10%, 2) 2.5 gal carboys)
    Get 1 gallon of muriatic acid to adjust pH and TA if it's too high.
    Maybe 2 boxes of Borax if the pH is really low!
    That will get you up and running for lots of fun before summer ends.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
