Thread: BBB is awesome
    Apr 2012
    SW Ohio
    456
    BBB is awesome
    i have had my 1st pool up since the middle of may i started out using the BBB method and has been smooth sailing, well i did a oclt for the first time last night (no issues) just wanted to do one....lol. my readings last night after sunset were fc-7.5 tc-7.5 cc-0 ph-7.2 (it was low because i added some m/a the day before because it was 7.8 and i knew i would be running my foutain today) alk-70 ch-100 cya-50 and this morning the readings were fc-7.5 tc-7.5 cc-0 ph-7.2 alk-70 ch-100 never tested cya but i lost nothing so today it was 95 degrees and sunny and just tested again this evening after 4 adults swam for 2.5 hours and the readings were fc-6 tc-6 cc-0 ph-7.4 (i knew the fountain would bring it back up...lol) alk-70 ch-90 cya 50 i lost 1.5 ppm chlorine which i owe it all to this site because i have learned everything i know from this wonderful site and it's pool wizards way to go guys and gals for giving me the power and knowledge ....BBB all the way.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Butterfly's Avatar
    South Carolina
    10,045
    Re: BBB is awesome
    Very nice job with testing, maintaining and understanding!
    You're done SLAMing when:
    Apr 2012
    SW Ohio
    456
    Re: BBB is awesome
    i owe i all to this great website......thanks again TFP.......Mike
