Results 1 to 8 of 8
Thread: Had to use Pucks for Vacation, now have smell
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Ok, I had to use pucks for 8 days while on vacation.
    Observations
    Pool is clear
    Little squares when light is on, I think this is filler
    Burning Eyes
    Smell, Seems the pucks have an awful smell, my daughter asked what smells like paint. I am back on BBB, but has any one else noticed a smell after going back to pucks for a short time? How long will it take to go away. I know it is the pucks because when I opened the chlorinator it was the same eye watering irritant that wafted in the air. I open it and run. There are remnants of pucks and a little water in there, I was going to run it out and go back to BBB, I am talking crumbs. Should I fill with a hose to dilute?
    Thanks
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Had to use Pucks for Vacation, now have smell
    Pucks make my water smell bad and leave a black ring in the skimmer. Distasteful to say the least. Oh, and the pH plummets.
    I'd rinse the feeder, why not?
    The stink shouldn't last too long. Putting some bleach in should sweeten it up.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jun 2011
    170
    I did notice my PH plummeted to around 7.2, glad I am not crazy. Started Bleaching the water yesterday, will rinse everything tonight. Thanks
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Have you tested your CC in addition to your FC? It's my understanding the CC in the pool can smell. It may not be showing algae but you may need to shock to get rid of the CCs and the bad smell.
    -- Guy --
    Jun 2011
    170
    FC was 7, CC was 0, PH around 7.2, that is what I remember. Yesterday the smell has subsided a little, pucks are pretty much gone, just little wafers at this time, maybe 2 of them like 3/16 thick. probably be gone today. I switched back to 12.5% 2 days back.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Can you just throw away the "chips" and not wait for them to dissolve?
    -- Guy --
    Jun 2011
    170
    Yup doing that tonight. Since I switched back to 12.5% (I got a good deal on it for 4 gallons and it is less to store) my pool has the sheen on the top back.
    Now if these thunder storms would pass.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Before I knew better I tossed two pucks into my chlorinator - I had the thing dialed pretty low and it took forever for this to finally go away. The entire time people complained about the Bleach Smell near the steps where the returns are that come from the chlorinator - I didn't put the two together until nearly the end of the pucks.
    As for rinsing? You shouldn't need to do so - it is bathed in water as long as you have it turned up from OFF. The crumbs will dissolve eventually and this will no longer be an issue.
