Thread: Intex Patch Repair Tip: Magnets
    While setting up our pool yesterday, I put an inch of water into the pool and proceeded to pull the wrinkles out of the floor. On the first pull, my finger nail busted in half and punched a small hole into the floor. Noticed the leak a few minutes later. Went to the local Dolphin-world pool store, bought a Boxer 100 patch kit and formulated a plan to hold the patch on the vinyl. This may be overkill but it appears to work pretty slick. I took two magnets saved from a salvage microwave, cut out a piece of cardboard and duct taped the cardboard to each magnet. The card board and duct tape act as something forgiving between the magnets. After applying the patch to the vinyl, I sandwiched the magnets together to hold the patch in place. To do this by myself, I used a long piece of cardboard with tape to locate the magnet on the inside of the pool while I was on the outside of the pool with the other magnet. Once together you can align them better by pushing thru the vinyl.
    If I had someone to help me, I suppose I could have used something flat, held by a second person outside while I rolled on the patch on the inside. It was just me so this worked pretty slick.
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Re: Intex Patch Repair Tip: Magnets
    That's a great fix! Thanks for sharing it! Slick is a good word for it! Good thinking outside the box (or the pool in this instance!).
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I like it as well, should also work for metal walled pools using one magnet on the inside. Computer harddrives have rare earth magnets in them that I've used in other applications and dead harddrives are easy to find.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
