Thread: No pump for 5 days - turning green on day 3
    Montreal, Qc
    6
    The pool pump failed on Friday afternoon and we had this extremely busy weekend (painting the house with friends). I ordered the replacement on Monday and I should get it in about 2 days.
    We had 3 days of 85+ degrees and the pool is turning green - slight visible algae at spots. I'm raising (and keeping) FC to shock level and plan to brush a lot to keep the water moving and chlorine "working". Is it feasible manaully? Any similar experience? Advice? Encouragement?
    Thanks
    Francois
    24k gallons, 16x32 ig vinyl. Jacuzzi 1.5 HP Magnum with Hayward sand filter. Newly added homemade solar heater with electronic controler. Switched to BBB June 2010. Adding borates...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: No pump for 5 days - turning green on day 3
    That's about all you can do. Unless you have a sump pump you can drop in and then just loop the hose back to the pool to circulate things. I wouldn't buy one, since the bleach to clear the green will cost less than a pump, but if you already have one....
    I've kept our pool up during week long power outages by adding bleach and brushing to mix it in. It is a lot of work. Trying to shock that way is possible but you better be feeling fit! It will be less work to let the algae grow and then kill it off after the pump is working again, though it will end up costing a little more.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Flap152:
    You probably have your new pump by now. But if something like this ever happens again...
    Here's what one user did to keep their pool clear and sanitized for one week without power and temperatures near or above 100F: http://www.troublefreepool.com/newbi...em-t48804.html
