Thread: Determining make/model of above ground pool
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I'm trying to confirm the dimensions of our AGP and at this point would like to know the manufacturer of it as well as model number/name. A lot of it is covered by a deck and half of it is pretty tight access. If there's a "typical" place I can get this info I'll crawl under. Just need to know where.
    Snakes alive! Hopefully not.
    Thanks again!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    22,468
    Re: Determining make/model of above ground pool
    If you'll post a pic someone may know the make and model. The strange thing about AGP's is that the mfg's usually don't put any marks on them to indicate make or model. The wall design and top caps are about all of the distinguishing marks there are.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Finally figured it out. Aquasphere. Thanks for the tip. It was on the caps but kind of hidden where the decking runs up against.
