Thread: Intex Ultra 16x48 Leveling question
    WE set up our pool this weekend. I checked the level on every bar around the top. And leveled all the legs in both directions side to side and back and forth. We have about half the water in it and one side has sunken a little. It is about 3/4 to 1 inch unlevel. Is there some tloerence on how far out of level it can be before it is unsafe? Should I be concerned or can I fill it the rest of the way?
    DAN
    12k gallon AG, Vinyl, Don't know my pump?LoL?, A Sand filter!, My hard work, hoses & attachments to clean!
    Taylor K-2006 Test kit!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Intex Ultra 16x48 Leveling question
    If you used fill dirt in the area near where the pole sank, you are likely to have increasingly worse issues. The pool area needs to be level, undisturbed dirt. If you dug dirt from one side of the pool and built the other side up (also known as cut and fill) it will continue to sink and it could cause damage to your poles or liner.
    -- Guy --
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Especially if one whole side of the pool has sunk. It's going to continue to sink as you put water in it. Water is very heavy.
    A whole side 1" low right now will likely be 3" low when full, or tomorrow... And then you risk your pool just falling over and flooding you out. While it may seem like a lot of work to drain it and re-level it, it's not something you want to risk. Once the kids get in and start splashing about, you'll see it wobble and spend the whole time freaking out about whether or not it's going to fail instead of enjoying it.
    Got a pic?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
