Results 1 to 8 of 8
Thread: OK, just re-tested - question re: CYA "tube" test
    Jun 2012
    Lafayette, Ca / USA
    260
    I think my numbers are getting better - pool really looks great.. (see results - any comments?)
    re: CYA test -- when you look down into the test tube, it says that black dot should "dissappear" .. Are they saying it must be totally GONE? what if there is a vague outline still? Reason I ask is that my figure comes to CYA=60 ! I have not added any CYA to the pool and removed the "puck" about 5 days ago ... The black dot is totaly invisible at 60 ... but is very very faded out at about 40 ...
    results:
    TC = 3.5 (I just added 98oz bleach to try to get this up some more)
    FC = 3.5 (making progress - this was at 1.0 on 7/12)
    CC = 0.0
    PH = 7.4 - 7.5
    TA = 120
    CYA = 60 !!
    CH = 280 (this is down from 300 on7/12/2012)
    CSI = 0.03
    pool temp = 86
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    30,287
    Re: OK, just re-tested - question re: CYA "tube" test
    If you have been testing outdoors, back to the sun and the dot totally obscures @ 60 then the result is 60. YOu are looking for obscuration...not partial obscuration
    Butterfly's Avatar
    South Carolina
    10,045
    Here's a link to Taylor Technnologies that shows pics of the CYA test process. This has helped lots of us get a good handle on the test. Scroll to bottom of the article for pics:
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    You're done SLAMing when:
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    642
    Practice makes perfect when it comes to the CYA Test. As techguy posted here earlier today, you can pour the test right back into the sample bottle and try it multiple times.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    May 2012
    Montville NJ
    545
    Quote Originally Posted by cody21
    That makes no sense. The less CYA you have in your water, the less turbidity the reagent will create, meaning you need to put more in the sight glass to obscure the dot.
    If the dot is totaly invisable at 60, then that is where you stop adding liquid. The 40 line is ABOVE the 60 line.
    Also, it does not matter when you removed the puck. CYA does not go away. The only way to lower it is to remove water add fresh.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2012
    Lafayette, Ca / USA
    260
    @phonedave -- thanks for clarifying .... You're right, of course ... 40 is Above 60 ... I think I need to re-do that test just to wrap my head around what's really going on ... And I think I'll try to do this test in the sunlight per previous suggestion (back to sun) . thanks everyone..
    Jun 2012
    Butler, PA
    336
    you can do the test a few times ~ empty the tube with the dot back into the bottle you used initially to mix and redo the test.
    I needed to do this at home & I had wished my son would have been home when I tested it the second day so I could have gotten his opinion. You could ask someone else after you have looked an gotten a number to take the test and see what they see.
    Just wanted to make sure I know you can redo the test and have someone else look too. I wouldn't let the sample sit around all day, but use the same sample and get a few readings out of it so you feel confident in the number you decide upon.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Jun 2012
    Lafayette, Ca / USA
    260
    excellent point !!
