Thread: OCLT Test Question
    Jul 2009
    Long Island, NY
    267
    OCLT Test Question
    When performing an overnight free chlorine loss test (OCLT) should I leave the pump running? Does running the pump have any effect on the results?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: OCLT Test Question
    I would leave it running. If you get poor mixing in the pool, some areas may not get a good dose of chlorine if you don't force the mixing.
    It's possible leaving it run for awhile at night after dosing and the night test...then having it run for an hour before you test in the morning may work, assuming your pump does a good job of mixing your whole pool.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    You can have the pump running. If you have a SWCG, it needs to be turned off though.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jul 2009
    Long Island, NY
    267
    Okay, thanks. I will shut off the SWCG and leave the pump running when doing the test.
