Thread: Back fill around pool wall yes no maybe?
    Here is my second question. I understand the sand cove on the inside of the pool wall, how about the outside of the pool wall. How do most of you handle this on your pools? I hate the thought of trapping moisture against the wall with more dirt or sand. Any thoughts. Thanks Foamer
    Asahi (used) 27' 52", 18,000 gal, Cartridge filter, Above Ground, 1 1/2hp pump, New install 8-1-12
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Back fill around pool wall yes no maybe?
    You don't have to back fill. If its a safety issue (like a big hole next to the pool) I would back fill. Mine is buried 28" and back filled. The pool doe not rely on the back fill to function as it was designed.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    I just got my pool up over the weekend and I think I'm going to back fill to the top of the bottom rails. I'm paranoid of erosion and standing water deteriorating the ground below the rails, I paid a lot of money for my sand and I want it to stay where I put it.
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
