Thread: CC at zero but FC at 11
    Aug 2011
    Watson, Louisiana
    57
    13,500 gallon above ground over. TC-100 test kit. I am getting a 11 FC reading and a CC of zero with a CYA of 40. Any ideas?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: CC at zero but FC at 11
    What does the water look like?
    An FC of 11 with a 40CYA is higher than normal but less than shock.
    -- Guy --
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    CC of zero is always a good thing. If your water is presently clear, your only issue is that you are over-chlorinating a bit. It is below shock level, so OK to swim if the water is clear.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Aug 2011
    Watson, Louisiana
    57
    Pool is a little cloudy but turning clear. I just vacuumed to waste and removed a good amount of "dust" from the bottom. I misunderstood I thought so CC was good. Awesome thanx all!
    elwood58's Avatar
    May 2012
    653
    Quote Originally Posted by bckcx2
    If your water heads back toward the cloudy side, you may need to take it up to shock level and go through the shocking process. Click on Pool School link at the top of every page. Do not stop the shock process until:
    Pass an OCLT
    CC less than .5
    Water Clear
    Aug 2011
    Watson, Louisiana
    57
    Will do thanks Elwood
