Thread: water coming out of backwash valve question.
    Jul 2010
    col. Ohio
    15
    Hi all, I gues this is a 2 prt question. first, the filter is 2 yrs old. water comes out the backwash valve when running. it's fine if in the recirculate position. but I guess thats not filterng the water, just keeping it moving, right? Why would it do that?
    Second.. would this cause no pressure during backwashing?
    How is this fixable?
    thanks
    10,000 gal. above grnd.
    300 # sand filter
    solar cover(do not use often)
    22,553
    Re: water coming out of backwash valve question.
    You're describing a leaking spider gasket in the multiport valve. They're pretty easy to change. And yes, that would cause the pressure to be low when in backwash too.
    Jul 2010
    col. Ohio
    15
    thanks for your help. Even tho its only 2 yrs old this would happen? would this be something easier bought online or pool store. I have found that online is cheaper than store?
    300 # sand filter
    Articfox918's Avatar
    May 2012
    Western, Wisconsin
    99
    Do you shut off your pump when switching the valve? This can mess things up if you are trying to change position on the valve with the pump running.
    POOL SIZE: 27 FT round 52" Deep on edges 66" Deep in center
    FILTER TYPE: Hayward Sand Filter
    PUMP SIZE: Hayward 1 HP Pump 60GPM
    FILTER SIZE/FLOW RATE: Unknown
    HEATER: None at the moment but in process of making my solar panels should be operational by next season!
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    My filter exhibited the exact symptoms as yours - water coming out of the drain port when it shouldn't. As Bama said, it was my spider gasket. My filter was 1 year old.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    22,553
    The biggest difference between buying it online and the pool store is that you can take the old one to the pool store to make sure it fits before hauling it home. You can't do that online.
