Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Please help me remove this rust and yellow stains - pics
    Hi,
    I had an inground pool installed about 3 years ago.
    The stairs have since developed these rust like specs on them, it was there following the first opening after my first winter. I've also had these yellow stains develop on my stairs as well as the jets (you can't see it in the picture), I know that magic erasers are normally recomemnded but I find they became so much less effective underwater compared to above the water line and it isn't doing much, especially due to the way the stairs are designed with grooves so you don't slip, it tears apart the strongest magic eraser available in just a few minutes.
    I would really apprecate some advice to finally solve this and to get my stairs back nice and white. Someone had told me that the rust on the stairs is probably due to the builder trying to ge rid of glue on the stairs when it was first built and it caused the rust to occur.
    Thanks[attachment=0:2jfjfeyk]rust on stairs.JPG[/attachment:2jfjfeyk]
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    22,537
    Re: Please help me remove this rust and yellow stains - pics
    Have you tried crushing some vitamin C tablets and putting them in a sock and rubbing them on the stains?
    Wow, really, Vitamin C, I never read that before, any particular brand or stength
    I mean something abrasive won't remove these stains, and you can feel the rust, it sticks out but it won't rub.
    22,537
    Yep, regular ole vitamin C tablets. The cheapest ones you can find. Nothing added. If it doesn't work it's not rust.
    I'll be proactive here, what do I try next if it doesn't work, I'm going to try the vitamin C tonight, just wondering if I could have tried a rust remover like CLR rubbed in to a cloth?
    How ground up should the vitamin c be? I mean won't it dissolve quickly when I have it submersed underwater rubbing away?
    22,537
    I think it'll work but if it doesn't we'll have to try and figure out what it is and what will dissolve it. Acid maybe the next step.
    Just crush it up good. You want it to dissolve through the sock enough to attack the stains. You can also try holding a tablet directly on the stains.
    Hi,
    It didn't work, I doubt it makes a diff but I noticed the pills I had were in chewable format. I tired rubbing the vitamin on the stains, I also rushed a lot of it and placed it in a nylon sock and rubbed that on it but not a dent.
    Would CLR work on something like this? Not sure what to try next.
    22,537
    Since the Vitamin C didn't work it's likely not a metal stain. Try taking a chorine tablet and holding on one of them for a little while. Let us know if that fades them.
    Qwaxalot's Avatar
    Jun 2012
    439
    Try scraping those little dots with your fingernail. Do they, sort of, come off? If they do, does the residue (on your fingernail) seem to be kind of green and slimy?
    If the answer to these questions is yes, you have black algae.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Quote Originally Posted by Qwaxalot
    It won't come off, or in such a small amount that i can't. Measure it, certainly not off when I try to scrape with my fingernail.
    Since I have a salt system I don't have pucks around, you think that this something I can buy in a single format?
    I have that super cocentarted chlorine in granular for when I shock at the start of the season, I'll go by the store and ask but I'm not confident they will sell one puck.
    Or maybe they sell some commercial version of a chlorine sponge or something like that, assuming its is even that. You can certainly feel the stain if you ru your finger on it but you can't pick it off.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    You should be able to buy individually wrapped chlorine tabs. Or if you have a friendly neighbor that uses pucks or tabs.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Walmart and Kmart sell individual pucks. That's what I used to add my CYA at the start of the season.
    22,537
    As said, Walmart has them.
    Bringing this one back up, I still have the rust type spots, vitamin c didn't work and rubbing a puck against it didn't work either.
    Any other options?
    I don't know if I dreamed this or not, but I remember one service person that thought it could be due to the installers having used something course to remove whatever residue was on the stairs after it was installed and this would be the result.
    Could there be any truth to that? And can it be fixed? It's actually a lot worse in some areas compared to the pictures.
    tcat's Avatar
    May 2012
    Austin, TX
    729
    Interesting read on stains: http://www.isaacspools.net/docs/vinyllinerstains.pdf
    If you have removable coping to see if the stain is coming through the liner, that would help diagnose the problem. Don't own a vinyl pool, so can't comment more.
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Quote Originally Posted by tcat
    In my case it isn't a vinyl stain, it's on the stairs which aren't vinyl.
    So as my season will be started soon I thought I would bring this one back up. I still haven't been able to get rid of this. Not with Chlorine tab, not with Vitamin C, assuming I've applied both correctly.
    Yes you can feel the spot with your finger nail but it can't be rubbed off, it can't be picked off, doesn't feel like it.
    I don't mind spending mine on pool store chemicals, is there anything commercially I can add to the pool to try and solve this?
    I didn't notice that original attached picture was lost, forum must have lost attachments with re-design?
  20. Back To Top    #20
    I see the attached picture in the first post just fine. You won't see it if you are not logged in.
