Thread: How to control/wire the 110v hayward 2 speed pump ?
    Jun 2012
    connecticut
    17
    Im gonna be putting a Hayward SP15922S 2 speed 110v pump in , and the question is , how is the speed being controlled in that pump ? there is a toggle switch that switches between , hot-neu1 and hot-neu2 ? is there a simple timer that I can use to automate the speed control ? (I would like to use it on low for 8 hours and on hi for 2 hours)
    Thank you for your help
    13k Gal all resin St tropez ABG
    Clean and Clear Pentair filter
    1hp 2 speed hayward matrix pump
    CompuPool CPSC36 SWG
    Build 7/15/12
    Re: How to control/wire the 110v hayward 2 speed pump ?
    There are timers you can get that can control both speeds, for example the Intermatic PE153. However, for most people it is simpler to use a timer that only turns the pump on and off and control speed manually. The only times you normally need to use high speed are backwashing the filter, priming the pump, and vacuuming, all of which involve manual intervention, so a manual switch works well.
    Jun 2012
    connecticut
    17
    Jason,
    thanks for your input on that.
    Build 7/15/12
