Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
Thread: Just starting BBB
    Just starting BBB
    Hi, Love the site and looking forward to learning a lot.
    I have some of these left over http://www.intheswim.com/Pool-Chemicals ... e-Tablets/
    Can I continue to keep using them while using BBB ?
    I also have this, which looks like I need a better kit.
    http://www.amazon.com/gp/product/B002NS ... 00_s00_i01
    Thanks
    Joe
    Thanks, Joe
    New Jersey
    - 15ft round Above Ground pool with vinyl liner (10 yrs old)
    - 5700 gallons, Sand Filter, 1.5hp pump
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Just starting BBB
    When you are starting out with BBB - you'll typically need to switch your clorine source to Bleach or Liquid Clorine "shock" (Same chemical different strength). The problem with the pucks you have is that they contain CYA which is a stabilizer that acts like sunscreen for the chlorine - but too much is not a good thing. Over time the CYA builds up and it becomes nightmarishly difficult to get the pool to stay algae free.
    If you add the pucks now you're likely to have too high CYA levels and the only recourse is to drain and refill part of your water until the levels are back down.
    Read "pool school" on the top right and come back with additional questions... these guys are here to help. Remember that one of the main cornerstones is that testing is needed and pool store tests are junk. Read the section on test kits - without a kit you're not armed with the knowledge you need to win this battle.
    Quote Originally Posted by UnderWaterVanya
    Thanks for the quick response.
    Thanks, Joe
    New Jersey
    Just ordered my TF-100 Test Kit.
    Keeping the faith.
    Thanks, Joe
    New Jersey
    30,414
    It just shipped!
    It just shipped!
    Great.. Haven't received it yet. Hopefully by the time I get home from work.
    Thanks, Joe
    New Jersey
    It just shipped!
    Can you PM me the tracking number?
    Thanks, Joe
    New Jersey
    So, while I wait for my test kit to arrive. I took a few pics and used a test strip (I know they are basically useless). The water is pretty clear but not OMG "look how clear that is". I stopped using the tabs and started using bleach. After taking my hand out of the water this morning my hand smelled like chlorine.
    This is what I have this morning with the test strip.
    PH 7.8
    FC 10
    Alkalinity 180
    Cya 100
    https://www.dropbox.com/s/iot9o6fzsc...717_071920.jpg
    https://www.dropbox.com/s/861bqyg2a7...717_071931.jpg
    https://www.dropbox.com/s/h65bbral3v...717_072005.jpg
    Thanks, Joe
    New Jersey
    Quote Originally Posted by TechJPC
    PH 7.8
    FC 10
    Alkalinity 180
    Cya 100
    Since this test strip is saying 100 on my CYA, do you think it's a good idea to backwash a few times just to be safe or just wait for my real test kit to get an accurate reading?
    Joe
    Thanks, Joe
    New Jersey
    22,544
    I'd wait for the good test kit.
    Just remembered I bought this last year for hurricane Irene (thougght my bsmt was going to flood). So I guess if I have to drain my pool, it won't be much of an issue
    http://www.amazon.com/Wayne-RUP160-6-Ho ... Water+Pump
    Joe
    Thanks, Joe
    New Jersey
    Did a quick partial test this morning before work. Figured if my CYA was over 100, I'd have to drain and refill. Question is how much do I drain?
    CL under .5
    PH under 6.8
    CYA over 100
    Thanks, Joe
    New Jersey
    30,414
    Is that still with the strips?
    No strips..used the tf-100.
    Thanks, Joe
    New Jersey
    The CYA level was less than an 1/8" below the 100 line on the tube. We also had a good dose of rain last night (heavy thunderstorms).
    Thanks, Joe
    New Jersey
    30,414
    You have three things going on that need attention...
    1. You have no FC....algae is on the way
    2. Your CYA is too high and you should drain about 1/3 of your pool, refill, then 1/3 again, refill and test.
    3. Your pH is too low. If you do not drain refill right away, you will need to bring your pH up to 7.0 or more.
    Gotcha.
    Regarding the draining ... Should I do that in one event or wait in between drainings or can I just drain a little over 1/2 at one time ?
    I did put about 1/4 of a large bottle of bleach from Walmart in this morning after I tested. I planned on doing the draining tomorrow evening (maybe tonight if I have time). I could have someone put more bleach in today for me while I wait to drain.
    Once the draining and refilling and testing is done, that's when I use the pool calculator to determine what to put in ?
    Thanks, Joe
    New Jersey
    30,414
    I misspoke about draining 1/3....I was thinking IG pool. With your pool, drain a little over half and then refill and retest. sorry.
    Get your pool filled back up and post your test results, and tell us what your water looks like.....you'll use the poolcalculator then to get your chemistry to the right levels.
    After draining and refilling , my CYA should be 30-50 ? What if it's up to 70 or more ?
    Thanks, Joe
    New Jersey
  20. Back To Top    #20
    30,414
    one step at a time. I think your CYA will be about 50 but let's see.
