Thread: Should We Change The Sand?
    Got new Intex Sand Filter last summer, used for the season. Thus far this summer I'm needing to backwash almost daily because flow through the output seems to loose strength, and that seems to be the only way to get the flow going really well again.
    When my husband put the thing in the shed last fall, we did not know that we should have drained the water out of it before storing it.
    Should we change the sand and put new sand in because of that?
    Intex 22' X 52" Ultra Frame with Intex Sand Filter
    Apr 2011
    Lynchburg VA
    393
    Re: Should We Change The Sand?
    Let me start by saying I have no experience with Intex filter but with most sand filters you should not need to change the sand in the filter after a season. Generally, the sand in the filter will last for years and years. I had seen people on here that have used the same sand for 15+ years. What does your water look like? If backwashing returns the flow to the filter it's usually because something is getting filtered out of the pool to clog up the filter.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Check the sand by opening up the filter. If it is still sand like you are fine. But if it has clumped up into clumps you can't break up by hand or has turned to rock it needs to be replaced.
