I recently set up a summer escapes 14 x 52 steel frame pool. I set up on a patio block deck. After I set up and filled I noticed that there is a 2.5 inch difference in depth. Also 2 of the poles on the low side do not touch the blocks.Is this something to be concerned of. I only have 2 more months of summer. Is there a quick fix to raising this? I am guessing if I put some risers under the high side it may work but also I am thinking it would cause more stress on the liner. Any suggestions would be great.
