I ask because .86 in not a multiple of .2. Four drops would be .8 and five drops would be 1.0. 43 drops is 43x.2 which is 8.6. No big deal if .86 was a typo but could be troublesome if you're basing your bleach additions on .86 and not 8.6.Gfamily said:I have the FAS-DPD. I got the results when I multiplied the number of drops needed from the R-0871 reagent to change water from pink to colorless (43) with the drop equivalence found in step 1 which was 1 drop= 0.2 ppm. Sounds like I did it wrong
Anyways you don't need to test to the .2 accuracy on the FC test. Instead of using the 25 ml sample, use the 10 ml sample where each drop equals .5 It'll save your R-0871 reagent. The 25 ml sample uses 2.5 times the reagent to get your results. A .5 accuracy is good enough.
Are you planning to drain some and replace your water to reduce the CYA?
