Results 1 to 7 of 7
Thread: been a month
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    been a month
    been a month since I have thrown in a bag of "shock" and used nothing but liquid chlorine. and I have to say I have NEVER seen a more clear pool ever. (once I got the Iron under control) however I am running a never ending battle with my PH and TA. as it comes out of the wall with a TA of 200 and PH of nearly 8 so I just keep hitting it with acid to try and get it down to 7.4-7.6 area. ANYWAYS it rained nearly 10 cm here today or 4 inches for you backwards Americans. (join the rest of the world) and my PH went up from 7.6 to over 8... so I tested the rain water. which happend to be 7.0-7.2... so I thought maybe the rain caused the water aerate? and raise the PH? it just made me angry I am tired of buying acid nearly every week!!! ARGH
    And no I do not have a good test kit yet. funds are VERY LOW as my wife is expecting baby number 4 end of this month. but over the winter I plan on ordering my taylor kit. but being canukcistan it will cost me an arm and a leg.
    or maybe my first born.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: been a month
    Yes rain does do a good job of aeration, you should thank it because it is helping you. Every time you add acid, your TA goes down a little. Until your TA comes down, you will most likely keep using lot's of acid. If you want to speed this up, you can use this process to lower TA.
    Quote Originally Posted by topher
    I know money is tight, but I do not understand your logic, since most of us save some on chemicals, etc. and avoiding algae outbreaks (that can be very expensive) that pays back on the test kit very quickly. However, you canucks are over a barrel on the price they charge up there for the kits.
    I here you! Many technical people down here, including myself use the metric system for most of our work. Why we didn't standardize on it as a country makes no sense.
    May 2011
    Clearwater, FL.
    446
    Re: been a month
    Hi topher and welcome to TFP!
    I would lower the TA to at least 120-130ppm just for starters.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: been a month
    This is not a very nice statement!!!!!!!!!!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    topher's Avatar
    Jun 2012
    136
    Re: been a month
    that was ment as a joke poolmama not to offend anyone I have some really good friends in Florida, Texas, Ohio, Washington, and Oregon. and we just make fun of eachother as we are all really family living in north America. but yet totaly different completely backwards to eachother.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: been a month
    Ok...just read it that way...sorry
    Installed May 2011
    BBB method
    Re: been a month
    I'm in the same boat with the TA and pH -- have a TA of 550 out of the tap Keep up on the acid, can you ship a kit to a friend and make a visit to the states? Eh, that probably costs more than getting it. I bought a fountain to help with the aeration part of lowering the TA but you can also point the return jets up a bit to break the surface of the water. I'm still working at it, but have moved it from 550 to 300 in a couple weeks. Just bought another 6 pack of acid today - found it cheaper at the farm store than the pool or hardware store.
    Good luck and congrats on the baby!
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
