Thread: Algae groth in over chlorinated pool
    I'm new to pools and have a black algae problem, at least I think it's bad I have shocked my pool (some times every other day) for a weak and a half - needless to say the pool is well over chlorinated (off the color chart) and the algae keeps on coming.
    Jim
    2,400 gal (12' x 36 ") - FILTER is a cartridge type skimmer - PUMP came with pool (Summer Escapes) - ABOVE GROUND -
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Algae groth in over chlorinated pool
    Welcome to tfp, jimjd3
    Are you sure it is black algae? What does it feel like? Is is slimy? Are you able to scrap the "head" off? If you want post some pictures, that may help with the diagnosis.
    With that said, if it is black algae, you will need to do the shocking process.
    To do this process an appropriate test kit is needed to be most efficient. See: http://www.troublefreepool.com/pool-...kit_comparison I like the TF-100 most bang for the buck.
    Pool school (link is in the upper right of each page) is the place to start. This is an article that may be helpful: http://www.troublefreepool.com/pool-...efeating_algae.
    I goggled some more and found it wasn't black algae after all.
    It's very dark green almost black buds about 3/16 in. around that kind of look like flowers they are free floating around on the bottom of the pool.
    I should also mention I have a small above ground.
    Thanks
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    You need a proper test kit and to report test results. If your CYA level is very high, then you may not even be shocking your pool, even though you think you are. See the Chlorine / CYA Chart and Defeating Algae.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Can you fill in your profile and pool information so we all know what pool type/size/surface/pump/filter and location you are at. It really helps us to help you.
    A couple notes, "Shock" is a product you buy in a store and not typically recommended here. "Shocking" your pool is a process described in the Pool School, and critical to the cleaning your cloudy or green pool.
    If you have a small, Intex style pool and your water is clean and inexpensive, I am going to make SWAG and suggest you drain and refill, especially if you bought pucks or bags by the case or bucket and they have been you main source of chlorine. If you have expensive , well or pump water or a truck brings it, fixing it may be cheaper... but not always.
    -- Guy --
