Thread: Help! Filter has no pressure.
    Please help! All of the sudden the SwimPro Voyager pump has no pressure. The filter basket will fill with water and then when the pump is turned on, it drains out and the output stops working. Tried removing the input hose from the pool to the filter to see if there was debris trapped....nothing in there. When the water is off and the filter basket cover is open, bubbles are coming from the input hose. When the filter is turned off, bubbles come from the skimmer basket. Please help! It's gonna be a hot couple of days here and I'd like to cool off in the pool. Thanks.
    From South Arkansas
    Intex Above Ground Pool with small filter
    16x48
    Probably holding around 5,000 pounds
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help! Filter has no pressure.
    Check to see that the skimmer weir can move freely.
    asxetos's Avatar
    Jul 2012
    Athens, Greece
    99
    Is the impeller intact and turning?
    Don´t be fooled by the sheep on my bike, I swim with fish in my sound equipped pool.
    22,551
    What type pool do you have?
