Results 1 to 9 of 9
Thread: Mustard/green film on walls = algae?
    I am still considering myself a newbie, although with the help of this forum I have been taking care of the pool by myself for the second season. My question:
    Every week -10 days I see a mustard/green film on the pool walls, mainly in the deep end. It brushes off easily (creates a cloud when brushed). I used the "maintenance" dosage of algaecide occasionally and I do not think I saw any difference.
    Is it algae or just dirt? What should I do? The water is pretty balanced, with PH currently at 7.8, as it tends to drift up every couple of weeks.
    Thanks!
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    30,432
    Re: Mustard/green film on walls = algae?
    Can you post test results?
    SWG with Plaster:
    FC 1.5- 2
    pH 7.8
    TA 70
    CH 220
    CYA 30 (I know, this is low)
    Salt is at 2800
    Guy
    Anything?
    Guy
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    With a CYA level of 30, the minimum for your SWG is 2ppm.
    Sounds like you're always at or below minimum. My bet is on algae and the need to begin shocking. Do you have a combined chlorine result? (TC-FC=CC).
    Your FC level should be above minimum at all times. That means you need room to lose some chlorine if say... the sun comes out or people swim. I'd shoot for 5-6 ppm.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    [center:26hxefk4]Aha! I see a clue!
    [/center:26hxefk4]
    Quote Originally Posted by guydot
    SWG with Plaster:
    FC 1.5- 2
    pH 7.8
    TA 70
    CH 220
    Salt is at 2800
    FC 1.5- 2 tells me you're using the color matching test. And even if it's right, it's wrong. With 30 CYA, normal FC is 2-6. You're below that, so you probably are just barely staying ahead of an algae bloom, and every week or 10 days it gets ahead of you.
    You're a prime candidate for the Shock Process. But to do it effectively, you'll need a decent test kit (defined in Pool School) and the How-to directions in
    Thanks! Sounds like I need to increase the clorine generation from 60 to 80 pervent and add CYA. Is shocking a must in my situation?
    Guy
    Richard320's Avatar
    Jan 2010
    19,067
    I'd say so - you have algae.
    Once the process is complete - not before - raise your CYA level up to 70ish, then the SWG can keep up with the losses to sunlight.
    Just to update and contribute to the knowledge base: it was algae. Shocking once then raising CYA and keeping the FC level at about 3ppm did the trick. I have been algae free for weeks now.
    Guy
