Thread: Raised SPA draining into the pool - Please Help!
    Hallo Everyone,
    I have raised spa with overspill, so when the pump is running the water is spilling into the pool. Everything is fine when pump is running. My problem is that, if I leave the the SPA drain open and the pump is not running, all of the water prom the SPA is draining into the pool. I did a little research and it is appearing the water is leaking from the SPA drain -1 through the skimmer suction-3 and the cleaner suction-4 (if I leave it open) into the pool. I'm not sure if the SPA water could be draining into the pool through the pool main drain? I only have actuators on the SPA and pool drain.See picture.
    I'm sure there is something wrong with the piping design or there is/are valve(s) missing, but need help to figure out what could be the best option.
    Is there a valve I can install on the spa drain pipe, so it can open when pump is running and close when stops? Or I have to install check valves on the skimmer and cleaner suction?
    Please, help me out with ideas!
    Thank you!
    Boris
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Raised SPA draining into the pool - Please Help!
    Welcome to TFP!
    Typically when a spa drains to the pool, it's a jammed check valve on the spa plumbing that isn't closing as it should. I'm having a hard time following your description; can you post a picture of the equipment showing the pipes and valves?
    http://www.flickr.com/photos/82663629@N04/7571921784/
    This is a picture of my piping . Basically, if the valve is left open and the pump is not running, the water from 1-SPA drain is flowing into the pool from the 3-cleaner suction and 4-skimmer suction.
