Pool water for house plants
iSmile said:
chem geek said:
What you need to worry about is the salt level as not all plants are salt tolerant and the salt level in pools is much higher than tap water (and of course much higher than rain water).
Is this because salt is a byproduct of something going on in the pool? Not all of us have specifically added any, and petunias have died!
Sent from my iPhone
All Chlorine sources add salt to the pool. At the bottom of The Pool Calculator in the Effects of adding chemicals section you can see exactly how much each adds. Depending on how much water you replace or don't replace, it adds up. There have been some mishaps when people change over to an SWG and don't test the salt first before adding.
Yes, when chlorine gets used/consumed it becomes chloride salt. When you add chlorinating liquid or bleach you are also adding sodium. So over time the pool builds up sodium chloride salt. For every 10 ppm Free Chlorine (FC) added by chlorinating liquid or bleach, it also increases salt by 17 ppm, unless there is water dilution. Though stabilized chlorine adds half the amount of salt (which comes from the chlorine), it also adds CYA and that causes problems far sooner than salt. Cal-Hypo adds salt in between these two, but builds up Calcium Hardness (CH).
Even after a fresh refill, if one has a plaster pool and had no salt or calcium in their fill water (which isn't usual, but let's take this worst-case example), then one starts out with around 350 ppm salt (measuring the chloride from the added calcium chloride).
