- Jun 22, 2011
- 141
I got my 24 ft matrix up and running today and ran a full test, below are the results
FC 0
PH 7.5
TA 70
CH 50
CYA 0
I've got stabilizer in socks hanging in front of the return which according to PC will bring my CYA to 40. I went with this as a starting point and will raise to 50 if need be, The pool gets full sun all day long but the temps haven't been too bad to were I want to take it straight to 50. I also added my bleach to the according shock level for a CYA of 40 so I think I'm good there. My question is my TA and CH are at the low end of the acceptable range but do they need to be a little higher??
Thanks to any and all that reply
PS - Pump is running on low right now because high scares me(that thing moves some water). Should I run it on high when I add chems or is it fine on low?
FC 0
PH 7.5
TA 70
CH 50
CYA 0
