Thread: Water over skimmer line
    Just had some water delivered today and because I told them I suspected a leak, they filled above the skimmer so I would have more water while it leaked away.
    I know it can't "skim" like this, but any problems running the pump in the mean time with the water so high?
    ~29k gal IG Vinyl Pool with Sand Filter
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Water over skimmer line
    No problem running the pump. You may even get a little skimming action, depending on how strong the pull is.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
