Thread: baby oil
    May 2012
    new york
    27
    baby oil
    about a week ago my little brother poured about 8oz of baby oil on the slide to make the slide faster. so all the baby oil was in the pool. now my levels are fine now my problem is my robot is not climbing the walls could this be because of the baby oil. the pool is cyrstal clear fc is 4.5 ph is 7.5 everything is good.. any suggestions
    26x46 Inground Pool SWG 36,000 gallons vinyl liner with 12' cement walls. cement steps, vamiculite bottom through out pool.Bio guard SWG ms-10 system, Mini max NT Gas Heater,Pentair Cartridge Filter CCP4200, pentair whisper Flo Pump 2/.33 hp.
    Re: baby oil
    A little baby oil in the pool is not a big deal. The oil will float and tend to collect in the skimmer. Eventually chlorine will break it down.
    I wouldn't expect it to affect the robot, though if the debris bag got oily it could reduce the flow rate which could affect wall climbing.
