Results 1 to 19 of 19
Thread: Adding CYA with a sock
    Mar 2008
    Central VA
    328
    Hello everyone,
    OK, I'm ready to start getting balanced for my SWG, and I read on the forum that I can put CYA in a sock and let it dissolve...so I tried it. Thing is, I may be showing some severe (and humorous) ignorance here, but I used a regular (old argyle) cotton sock...was I supposed to use a skimmer sock or other similar type material instead?
    My cotton sock is pretty thick, and it seems to be letting the CYA dissolve, but VERY slowly. I put probably 2 lbs. in it, and it hasn't dissolved yet and it's been over 48 hours.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    IkeRay's Avatar
    Houston, Tx
    154
    go get a nylon sock from wally world (or which ever store pleases you), that should help a little bit more.
    are you squeezing it and helping it along? also, is it just chilling in the skimmer basket, or do you have that baby dangling in front of a return jet?
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Butterfly's Avatar
    South Carolina
    10,045
    I have used old white cotton socks and and they worked pretty good!
    You're done SLAMing when:
    Guest
    CYA is slow to dissolve. It can take up to a week.
    Casey's Avatar
    SW PA
    10,444
    I used my old ankle sock and a ponytail holder.
    I threw it on the bottom and checked it after a couple days... it needed help so I used the pole to fish it out and held it in front of the return. The water was so coooooold! It ended up in the skimmer!!
    Mar 2008
    Central VA
    328
    OK I do have it hanging in the pool, but when I picked it up today alot 'poofed' out of it so I need to help it along. I'll hang it closer to the return.
    Thanks!
    Todd
    Fayetteville, Arkansas
    220
    Added the CYA to the oasis (green lagoon) today ... man I think the way to go is with a knee high, just like the one you may use on the skimmer baskets . . . tie that sucker off to a nearby plant container with whatever you have handy, hang it in front of a return jet and let her go. After awhile you may want to adjust it so that the jet stream hits it dead on. Simple, simple, simple.
    20x40 30,000 gal IG Liner, Pentair II Sand
    Guest
    I just pour the cya into the skimmer and don't clean the filter for about a week. I leave the pump running continuously for the first 48 hours. It's the easy way to do it and is actually the way recommened by many of the product companies. Why make it more work than it really is?
    Mar 2008
    Central VA
    328
    Cool, thanks again, Waterbear, I put 3 lbs. in my skimmer last night. With 7 lbs. total needed, I was beginning to wonder if I could get it all dissolved by the end of summer!
    Todd
    I just emptied and refilled 1/2 my water the other day. I used the sock method (wife's panty hose) prior and dangled it over a return, if you squeeze it every 10 min or so it takes 1 hour to dissolve. This time after reading a post that stated to dissolve in warm water, I tried that. I still put the CYA in a sock but put the sock in warm water and squeezed it. It took 20 minutes this way.
    I was in a hurry because I wanted to test my water the next day to see if the refill helped my CH issue. I guess if you are not in a hurry just pour in to the skimmer.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Guest
    CYA is slow dissolving so even if you try to dissovle it by squeezing it it will not dissolve quickly. It might squeeze out of the knee high or sock and siperse in the water but it will still take several days for it to show up on water testing. Hot water does not appreciably improve it solubility either. The EASIEST way to add it to your pool is pour it in the skimmer and don't clean your filter for a week. Test it in a week.
    Pool Owner Patience should bee applied liberally to the pool owner during this time!
    Feb 2008
    New Milford
    11
    Refilled my Hot Tub 100% BBB Method now
    I recently drained and cleaned my Hot tub and refilled it. This time I am using the BBB method only and not the Spa Shop chemicals. For the first week, I've added about 1/4 cup Clorax Bleach and 2 oz of Boraz. My readings are looking so much
    better now. For a while before my CYA was running over 300.
    Now, my FC= 5, ph=7.3 CYA=30
    I am hoping this trend continues .
    Ron DiLauro
    MasterSpa Envison Owner
    Mar 2007
    San Rafael, CA USA
    12,082
    Ron,
    You need to start out using Dichlor for about a week to get the CYA up to around 20 ppm or so. Otherwise, you are over-chlorinating your spa and can cause more rapid damage to the hot tub cover as well as fade your swimsuits and oxidize your skin faster. You want SOME CYA in the water, just not too much. So using a little Dichlor to get some CYA into the water is a good idea (about a week at 4 ppm FC per day gets you to around 25 ppm CYA). After the initial use of Dichlor, you then switch to bleach until the next drain/refill.
    You may notice that the pH tends to rise when using the bleach. This happens much more in a spa than in a pool. If you have an ozonator or other aeration feature (aerated jets), then this pH rise will likely be much worse. You can add acid to compensate or reduce the amount of aeration, if possible. Unlike in a pool, some of the pH rise is due to outgassing of chlorine itself, not just carbon dioxide, so there's not much that can be done about that except to reduce the amount of aeration (i.e. lowering TA doesn't help as much as it does with a pool).
    Richard
    Since my only return has a Poolskim attachment, I put the CYA in a doubled-up knee high and stuck it in the skimmer basket this time. I checked the next day and the knee high was empty.
    I like the simple 'pour directly into skimmer' suggestion. Might just do that next time.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Quote Originally Posted by MeSue
    Hello Sue
    I think it would be a good idea not to backwash for a few days, the cya has probably gone into your filter and still needs time to dissolve .
    Cheers Happy swims Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Guest
    Quote Originally Posted by frankthailand
    Hello Sue
    EXACTLY!
    Hello Sue
    Thanks, Frank. I backwashed right before adding the CYA, so no problem there. Will be a week since adding tomorrow.
    Sue
    Re: Adding CYA with a sock
    Does adding the CYA directly in the skimmer work for cartridge based filters too? I can't backwash (it's not a sand or de/filter unit) as people keep mentioning (not to do for a week after adding the cya), so I wanted to make sure that I don't harm my filter by adding the cya directly through the skimmer.
    Thanks
    30K gallon, In-ground Gunite
    Central NJ
    Yes, you can add CYA to the skimmer with a cartridge filter.
