Thread: CYA test
    CYA test
    I have been using pucks since I opened my pool to get the CYA level up and plan to stop once they are close to right. I tested today and with a full vile I can still make out the black dot vaguely. So I'm guessing that my level is still less than 30 and can use a few more pucks until the CYA increases. Is this a safe assumption. I only have the HTH 6 way test kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: CYA test
    You are likely OK for now. Just remember, CYA is the gift that keeps on giving, and not always in a good way. Make sure you do not overshoot.
    Telling us more about your pool, it's setting, and where you are located, wil help us advise you further on your CYA goal.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
