Thread: New Type Of Algae???
    Can somebody please tell me if there is a algae called scga algae. My neighbor said he read about it somewhere on the internet. He said it is highly resistant to CL. It mostly gets into small crevices & indentions in vinyl & plaster pools. I do have some type of substance that continually reappears in these places in my vinyl pool. I can brush it away or vacumn it to waste,but it always comes back in the same locations. My water is crystal clear . I have been on BBB since May 2011 with great success. I just can't lick this,whatever, that won't go away. THANKS for any advice. fc 5.0,ph7.7,ta 70, ch 50,cya 40. TFP test kit
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: New Type Of Algae???
    Small Cell Green Algae (SCGA) can be a pain, and is in fact a little resistant to chlorine, but typically not shock levels. You do not list CC in your numbers, but likely have some. Do an OCLT and go from there.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    30,414
    I remember reading somewhere there are over 7,000 species of algae. They all have one similarity....chlorine kills them
    If you have living algae in your pool, regardless of it's name, you do not have adequate chlorine.
    The answer is to increase the chlorine to a level that will kill the algae. Perhaps you need to shock but, if you return to your previous FC levels, the algae will return, too.
    Thanks for the reply to my question about the scga algae. I do keep my cl at chart target level per cya reading. My cc has never been over.5 and normally at 0. I did shock one time with 6% bleach with the amount the chart suggested. Maybe it's just dirt or silt. Until May of this year I used my well as water refill in the pool. I'm thinking it just might be from that. Thanks again for all help.
