Results 1 to 9 of 9
Thread: What is this??
    Aug 2007
    Athens, AL
    42
    What is this??
    At my pump/filter area, and in between the 3 returns and the 2 skimmer pipes, where they go into the ground, is a standpipe that has water that is a couple of inches below the opening of the pipe, any thoughts?
    hope I gave enough detail.
    Thanks in advance
    Tony
    ______
    My Pool set up:
    28,000 gal, 40x32x16 True "L" IGP, 3-8.5 ft depth, Hayward 1.5hp Super Pump, Pro Seriews 300# sand filter, 2 skimmers, 3 returns, Barracuda III suction cleaner
    Jul 2007
    Sahuarita, AZ
    278
    That's the mounting location for your flugenbaffler valve. It's usually plumbed directly into the farginmagiggy but in your case the PB seems to have missed this step. This is very difficult to fix yourself as a klaxxon wrench and a triaxial gauge are required to correctly align the valve. If you don't have those tools then you'll likely be paying big bucks to a pool installer to do the install.
    On the up-side you can safely ignore my entire post since I have no idea what I'm talking about.
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Aug 2007
    Athens, AL
    42
    LOL,
    Im pretty sure I got farther into your post before I realised what you were doing....too funny. Thanks for the laugh!!
    Tony
    ______
    My Pool set up:
    maybe a photo would help?
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Until the right answer comes along.
    I had a similar pipe.
    Mine ended up being the "OLD" waste discharge pipe, that apparently clogged up on the old homeowners.
    They cut it off, abandoned it, and went with the Flex hose to the garden approach instead
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    Guest
    Quote Originally Posted by EskimoPie
    We usually do!
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Could this be the overflow pipe? I have one off of my auto-fill now. Currently it has a 90 and terminates vertically after about a foot of pipe. I will be plumbing this into my drain system and out to the street. Possibly someone forgot to tie it in and there it sits?
    Could it be the air intake for the spa jets? --- no that can't be it --- it's flooded....
    Maybe it's a head calculator! 30 foot vertical section of pipe -- see how high the water will go!
    Just a few ideas.....
    Stever
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    If this is an older pool sometimes lines were installed to be used for pool cleaners. It would only be completed if the owner bought the cleaner. Otherwise the pipe just sat there unused.
    Aug 2007
    Athens, AL
    42
    I will try and take a picture and get it posted
    Tony
    ______
    My Pool set up:
