Thread: Algae ring in skimmers
    Hello everyone
    I have been having a problem with a predominately black with a little bit of green build up around the inside of my skimmers. Assuming this is algae. I don't have it anywhere else except a little bit on the rail of my auto cover. Pool water is clear. Balancing is good except this year my free chlorine has been tough to keep consistent. I've used a lot of tablets. I have been using a sponge to clean my skimmers but I'm getting tired of doing it everyday. Does anyone know what,where why and how I can solve this problem.
    both skimmers get it & one is worse than the other
    20000 gal
    D.E.
    5 year old pool
    33x16 (21,000 Gallons) Vinyl Inground Pool, 1/2 HP Whisperflo, Hayward Sand Filter, Pentair Mastertemp 300, 1 AquaLamp, 1 Skimmer, 1 Main Drain and 4 Return Jets...Maintained with BBB Method
    30,431
    Re: Algae ring in skimmers
    If you have algae, your chlorine level is too low or has been too low in the past.. It really is that simple.
    Posting a complete set of test results will be helpful to try to get you more precise information.
